At least the terminal stays put... lol :01nocomment8so:
It looks as if your amp had drawn so much power making it melted ^_^
Mids/Highs: stock Bang & Olufsen
Lows: Image Dynamics IDMax 12v.3
Power: Sony Xplod XM-D9001GTR:Knukonceptz 4 gauge
Box: 1.75 cu/ft Sealed
Past: Pioneer Premier TS-W1207 (2)/ Rockford Fosgate P210/ Image Dynamics ID10V.3/ Infinity Reference 311A/ Audiopipe AP-18001D
wow
how thick was the solder wire?
honestly, using a thinner wire melts almost instantly so you do have to deal with over heating, and melting the rubber
just clamp the cable, and get yourself about 2ft of some thin gauge solder, pre heat the terminal- UN- crimped for about 20 seconds or so, then feed the solder in to the strands, and the terminal while it melts fast
Ahh, ok.
I got "rosin core elctrical repair solder" wrong kind?
Thanks.
wow
Umm... 1/8" diameter.
the wiring kit came with a 100a fuse... my amp came with a 100a fuse. o.O
unless, there's something i'm missing, it should be fine. LOL.
id just use the thinner stuff, melts easy, just like melted butter, then its absorbed in to the strands, not balled up and globbed up like thicker gauge solder
If you are useing a torch...the trick is to aim the flame away from the wire..that way all the heat stays in the metal not the jacket!!!
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
