like title says if i were to wire up a Saz-3000d to my 4 T2s (dual 2 ohm so a final load of 1) what kind of power will i see in the 12-14 volt range.
NoFearX18 said:
trainman0978 said:
http://www.soundsolutionsaudio.com/forum/i...?showtopic=9952
Pyramid 50 Amp Power Supply
8 AWG from supply to batteries
Kinetik 2400 Battery
Duralast 1000 CA Battery
2 AWG between batteries
4 AWG from batteries to amp
Fluke AC current / voltage meter
Sears DMM
Measurements:
65.8 volts
49.2 Amps
1.33 ohm calculated rise from 0.6 ohm DCR **
3237 Watts
14.4 volts rest dropping to 10.75 volts
follow the link. it has more info and details
i remember reading from jacob that dropping to .5 ohms wont give you that much of a gain...if anything you'll get hotter and lose efficiency. so it's better for competition applications to go to .5 ohms
Edited by ExpoSport
IMO... for daily... 1/2 ohm is not worth the added current draw, stress on the amp, and lack of full warranty support and coverage.
You will gain some power... but not enough to really justify it unless you compete in SPL.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
damn...so that option is ruled out i want around 4500 watts. my fuckin t40001 put on a lil fireworks display last night and now i need a new amp. im thinkin of sending it in. getting a new one. maybe selling it and going to a new amp but i need around 4500 watts.
Edited by Chode69
NoFearX18 said:
trainman0978 said:
something to ponder but that will take me from an already low 145.6 to a 144 flat (about)
if anything i would like to step up power...
NoFearX18 said:
trainman0978 said:
If your primary concern is the number on the meter then you may want to go with more power - you won't lose a full 1.5 dB, that is theoretical. Most likely it would be 1 dB or less :)
You could run the 3000D @ 16 volts and get more power if that is an option.
- Jacob Fuller
If you look at the test results, you will see that it did over 3000 watts while dropping to 10.75 volts. With a strong electrical system, it will make you happy.
Team Carlisle Acoustics - Team Sundown Audio
2010 MECA DB3 World Champ 127.2
2010 MECA DB3 KY State Record 127.3
2009 February MECA Member of the Month
2008 MECA DB2 World Champ 131.9db
2008 MECA DB2 KY State Record 129.1
2008 MECA Neighborhood Nuisance
2007 MECA AS2 KY State Record 144.2
  • Who's Online   0 Members, 0 Anonymous, 1358 Guests (See full list)
