id rip it all out and start over with something thats actually calculated out and has a Solid basis rather then a hatch as the back of the box and all the other bad things i could point out but i wont so everyone doesnt whine about it.
I'll just keep it short and stay with "start over"
i dont know all of the technicalities of bandpass boxes, as far as designing them, but they do take up a lot of space. and from the looks of it, you're already tight on space. so i'm not 100% sure if you could use all 32 of your speakers. meaning you wouldnt be able to use both amps. unless you stepped up on speakers that needed more power since you're lookin to get new speakers anyway. i'd PM forevrbumpn and ask him some questions.
The So Called ported side seems way too small for 32 10's.
How many cubes is the back chamber?
The back area is roughly 25cu. And the "ported" side was the top. It was going to be sealed.
Well, the fact of the matter is I am not finished with it. The plan was to seal the back and flare the front to conform to the B-pillars like walls are supposed to. Yes, right now it is still nasty looking, but I never said it was done. And the videos I posted were TESTS.
Play with it first man, dont't give so easy. It is good to be different some times...
Haha, I'm not giving in! I am actually just getting lazy and want to start a different design!(...contradiction much? :lol: ) I love installing and I'll do it a hundred times. Even if I found a wild 160+ setup, I would most likely tear it out and try something new. It's just the way I am.
Once I go through everything, I'll probably buy a new car and start with that or do work to my van.
Need an install? Hit me up.
[email protected]
I think you guys would like some of my new ideas though.
EDIT: And remember, I'm still learning. I've learned so much from this build alone! Each time it's going to be better. I promise.
[email protected]
whats your max dimentions... i wanna see somthing
R.I.P!
(Nov-29-2009)
92 explorer
current build
Dimensions on what exactly? I'll try to answer...
Rectangular Box built outside to put in: 40 long x 36 wide x 30 tall
Rectangular Box built inside: 40 long x 36 wide x 36 tall
Trapezoidal Box built to conform to car for MAX space:
- Front area(Pillars to rear tire wells comfortably): 14 long x 52 wide x 41 tall
- Back area(tire wells to rear hatch): 30 long x (36 w/o wells or 44 w/ wells) x Curve (<41")
Rectangular "Boxed" Box: too many factors to remember but similar to ^^
I could "box" it all up and that's my plan with the next design, but those angles added more space which I figured I needed for this one.
What were you trying to find out?
[email protected]
i'm looking for building inside the vehical
R.I.P!
(Nov-29-2009)
92 explorer
current build
