philip Posted December 16, 2008 Report Posted December 16, 2008 this is how i figure it out. if my port is 3", i cut one side at 45 wide. do like above and set your guide to 2". you will end up with roughly a 3" wide 45. assuming you already 45'ed the port wall and there you go, width is basically even through the port turn.
numatik Posted February 28, 2009 Report Posted February 28, 2009 when I do my 45s I always use the clamp and straight edge method using my skillsaw. pushing boards that small through the saw are frightening! any tips on how to throw it through a tablesaw without a kickback? maybe im just bad with pushsticks, anybody else have this problem? Gary 'Numatik' Eberle West Sacramento, California Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento. http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/ "What doesn't kill you makes you stronger. I am proof" - Numatik
Pioneer~Saturn Posted March 9, 2009 Report Posted March 9, 2009 Nice post-up, noob JK, ink haha Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
aznboi3644 Posted March 9, 2009 Report Posted March 9, 2009 when I do my 45s I always use the clamp and straight edge method using my skillsaw. pushing boards that small through the saw are frightening! any tips on how to throw it through a tablesaw without a kickback? maybe im just bad with pushsticks, anybody else have this problem? good sharp blade and correct blade depth
numatik Posted March 10, 2009 Report Posted March 10, 2009 good sharp blade and correct blade depth what kind of blade do u use and what depth for say 1" mdf? i usually have the blade about 3/8in higher then the board Gary 'Numatik' Eberle West Sacramento, California Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento. http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/ "What doesn't kill you makes you stronger. I am proof" - Numatik
Hostility Posted March 20, 2009 Report Posted March 20, 2009 what kind of blade do u use and what depth for say 1" mdf? i usually have the blade about 3/8in higher then the board should you 45 corners in a sealed box? or would it make a difference? im talking rectangle reg sealed box. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
slugdub Posted March 22, 2009 Report Posted March 22, 2009 should you 45 corners in a sealed box? or would it make a difference? im talking rectangle reg sealed box. Uh, I'm sure it wouldn't hurt. But I doubt it would make any difference. The whole idea is to keep all that wind guessing when its being forced out. Kind of like building a castle with fake stairs to fool ghosts. Or maybe its more like Feng shui for your sound waves
Hostility Posted March 25, 2009 Report Posted March 25, 2009 Uh, I'm sure it wouldn't hurt. But I doubt it would make any difference. The whole idea is to keep all that wind guessing when its being forced out. Kind of like building a castle with fake stairs to fool ghosts. Or maybe its more like Feng shui for your sound waves i didnt think it would do anything, but never know, thought i would ask. thanks 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
Jville140db Posted July 29, 2009 Report Posted July 29, 2009 Uh, I'm sure it wouldn't hurt. But I doubt it would make any difference. The whole idea is to keep all that wind guessing when its being forced out. Kind of like building a castle with fake stairs to fool ghosts. Or maybe its more like Feng shui for your sound waves Feng shui for your soundwaves very nice lmao. I think fill would help more in a sealed box app than 45ing the corners but then again it would help seal the box more. Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
skittlesRgood Posted July 29, 2009 Report Posted July 29, 2009 when I do my 45s I always use the clamp and straight edge method using my skillsaw. pushing boards that small through the saw are frightening! any tips on how to throw it through a tablesaw without a kickback? maybe im just bad with pushsticks, anybody else have this problem? i cut my 45s out of the 2x4s i used when i do my 1st cuts on the big sheet on mdf. all you need is a buddy on the other side of the saw. feed it most of the way through and have him/her pull it the rest of the way off. just be sure to teach them what to do. my friend let his side drop after i let go... since it was a 45 it kicked out really... fighteningly. and tell them not to squeeze the pieces together and pinch the blade. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
