get back to work
R.I.P!
(Nov-29-2009)
92 explorer
current build
negative, dad had sugery today and he was the only one able to help me move t he box around
DC.jpgDC POWER
fair enough
R.I.P!
(Nov-29-2009)
92 explorer
current build
It's a full-size truck, in a wall.
Took all the seats out.
Posted Image
I have not cleaned the carpet since i bought it (febuaury) But ive only driven it a few times so i dont think much of that mess is from me :(
Posted Image
Had to make sure the height fit. I got kinda scared when i took the back seat out and the middle was higher than the outside. :fool:
I still have to cut braces, put the baffle on and cut out the ports.
DC.jpgDC POWER
seriously how do u fit 22 cubes in an ext. cab?
Im struggling for 14 in a Crew Cab....
it is somewhat easy. i can fit 30+ in my f150 if i use the whole back section of my extended cab.
forgot to add looking good man.
----reference's----
meade916
i think ima have trouble fitting it in the door, it does not open wide enough :( might have to pop that sucka off http://www.stevemeadedesigns.com/board/public/style_emoticons/default/tease.gif
DC.jpgDC POWER
Hey, where did you get the idea to use those subs? :)
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
