Here we go again. Everything is in and has been roughly tuned. Loud as all hell. Much louder than before. And I know the amp has more because my voltage even with the second battery and 225 amp alt is dropping fast.
The list:
'96 Jeep Grand Cherokee
1 Fi BTL 18"
1 Sundown Audio SAZ-3000d
1 Rockford Fosgate p500-2
1 Pair Infinity Kappa Perfect 6.5" components
1 Pair Alpine Type R Coaxial 6.5"Alpine CDA-7897 Head Unit + 6 Disk Changer
225 amp Excessive Amperage alternator
1 (soon to be more) Powermaster d680 battery.
Sub wired down to .5 ohms.
I built the box wrong, but it sounds good and gets down so I'm gonna be keeping it. These are the original plans, however, my box I put the port along the entire length of the bottom instead of the side, so it is hella huge. But there is no noticeable port noise so I'm fine with it.
Posted Image
Also, because I simply do not have the time and tools to do the electrical, my buddy as St. Lucie Sounds hooked me up. Installed amp, sub, battery, and tuned, along with changing around all my old wiring and stuff. Nice and clean.
Pics of box when it was made will be on soon. Final pics and vids,....gonna be a while, I don't have a cam here.
A vitrolic, megalomaniacal sadistic psychopath.
did you buy the sub used? ida tryed to stay away from the half ohm wiring if your using this daily
nope sub was new. I went easy on the gain, and the sub and amp barely get warm so far so I will ease into it and see where I feel comfortable. Also I will be getting an MLA module next time I hit some money and at least one more battery, which will definitely help the amp out.
maybe think about 2? those d680s are tiny bro
oh hell yea, I was talking more along the lines of a d3100 or whatever there big boy is up front, and one more in the back.
yeh i'm sure stepping up to bigger battery(s) would help out a whole lot. you already got the HO alternator covered.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I've got a D3100 in my car running 2 SAZ1500d's off the stock alt. I've also got a 950 amp duralast up front and the lights still dim like crazy. You may run into the same thing even with a D3100. Are you having any issues like that now? I've tested the drop when burping and I only drop down to 12.6, but with the lights on I'm sure that I'm dropping to high 11's.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Oh yea, I can't play my shit full blast at all or instant voltage drop, my next piece of equip will be the 3100 up front, so we will see how that does. I am being careful enough that I'm not worried about destroying my equipment, until I get a MLA and my voltage problems taken care of.
nice dude, once you give'er I wouldn't be surprised if you started bustin the fuse to your amp. Scared the hell outa me when I did lol
Why did it bust? Shouldn't if I keep the voltage up right?
