loganberry Posted November 13, 2008 Report Posted November 13, 2008 im looking for a dual anl fuse holder, i want 2 0 gauge inputs and 2 0 gauge outputs and 2 fused spots, 1 for each cant find anything anywhere, i see lots of single ones, id rather have a few duals then lots of singles... ill be runnin 300 amp anl fuses too thanks logan My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted November 13, 2008 Report Posted November 13, 2008 you could make your own I dont really think they make dual anl
Nightshade Posted November 13, 2008 Report Posted November 13, 2008 I run two singals in my car. I doubt that your going to find a dual anywhere. You could use a circuit breaker that uses ring terminals to connect to it and run it that way. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
loganberry Posted November 13, 2008 Author Report Posted November 13, 2008 I run two singals in my car. I doubt that your going to find a dual anywhere. You could use a circuit breaker that uses ring terminals to connect to it and run it that way. i have those now, but i like the look of these anl holders, what are some good brands i should be looking at, ive found a few audiopipe ones that dont look too bad, ill just run singles i suppose My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
RamenNoodles Posted November 13, 2008 Report Posted November 13, 2008 I just go for cheap anl fuse holders. Name brand doesnt really matter unless you are worried about them looking all fancy and stuff. Diablo Audio Technologies Fi Car Audio Ascendant Audio
Btrash Posted November 13, 2008 Report Posted November 13, 2008 Googled a few: http://www.sonicelectronix.com/item_3456_M...+PACKAGE+-.html http://www.ikesound-car-audio.com/rec/959-...Pipe-CQ-3422PD/ Doesn't really give the specs of the input/outputs though. EDIT: well, ignore the first link since it says discontinued and the second one is probably the audiopipe one you already saw..... I'm retarded
reinke Posted November 13, 2008 Report Posted November 13, 2008 i can check my friend jakes shop. i know he has a shit load laying around. i will see how much he wants. how many do you need. ----reference's---- meade916
loganberry Posted November 13, 2008 Author Report Posted November 13, 2008 i can check my friend jakes shop. i know he has a shit load laying around. i will see how much he wants. how many do you need. if there singles 5-6 if there doubles ill get 3 main reason im lookin for doubles is cause some singles can get expensive as hell!!! the audiopipe ones arnt too bad but im still lookin at 90-100 bucks just in fuse holders My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
loganberry Posted November 14, 2008 Author Report Posted November 14, 2008 I just go for cheap anl fuse holders. Name brand doesnt really matter unless you are worried about them looking all fancy and stuff. does it really matter, any other input? My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
RamenNoodles Posted November 14, 2008 Report Posted November 14, 2008 Logan, these are the ones that I bought. Work great. simple looking and are cheap as shit. They also come with a free fuse. http://cgi.ebay.com/4-0-1-0-GA-ANL-DISTRIB...%3A1|240%3A1318 Diablo Audio Technologies Fi Car Audio Ascendant Audio
