Sundown Audio SA-12 Prototype
600-watts RMS / 2.5" Coil / D4 configuration
Estimated MSRP - $200 USD
ETA - Don't have one yet, will be testing prototype in a few weeks
Posted Image
Posted Image
Posted Image
Yes, it will have "Sundown Audio" on the dust cap by the time it reaches production.
Designed to be used as a pair with the SAE-1200D.
Will first be available in 12s when production is ready, then other sizes later (no 8s or 18s).
May see some changes before production but you get the idea :)
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Now thats a nice sub, a VERY solid entry level sub for Sundown
Now I can give my son a graduation present, Thanks Jacob
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
Man, you've got a hell of a line up from the everyday person all the way to the heavy hitters.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I can see two of these in my single cab, when they come as 10s
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
So far so good in testing.
I used the old test box from the VW in the Jeep... which is ~2 cubes tuned around 30-35 Hz or so, port nearly touching the hatch (eg: very poor setup for getting numbers).
Peak still @ 50 Hz -- 138.3 dB with ~720 watts or so.
I played music with constant power from 500 - 720 watts clamped in this box for 5-10 minutes. Woofer did not display any mechanical stress except on 720-watt peaks -- will probably make the magnet stack taller for production to avoid that as the coil can contact the back plate at 26.25mm of excursion, which I was able to achieve.
I also played the 50 Hz tone for several minutes at the same power level as before - score stayed pretty constant.
I then turned the frequency up to 60 Hz and let it play... didn't really clamp the power at first but about 20 seconds in I got curious. Sub was seeing 1800+ watts clamped power and by the time I hit pause was doing so for about 40 seconds or so. Sub is still just fine.
So... probably 15 minutes or so of at least 500 watts and as much as 1800 watts on sine wave material and no issues at all.
Design seems to be meeting it's goals so far.
I want to make a top plate for my SPL box to see what it does in there as well just for kicks smile.gif
PS: I made a mistake on my spec sheet for the factory... forgot to tell them to make the coils D4 so I got S8 coils... I have two 3000s strapped on it to get this power level smile.gif
Oh yah... and most importantly the driver sounds pretty darn good to. This test box is tuned low so I was able to get a feel for the sound a typical customer will experience and I am pleased with it.
- Jacob Fuller
I think thats a pretty good review, minus the single 8ohm config... lol
But 500-1800watts on a 2.5" coil is damn good
cant wait to see these bad boys
  • Who's Online   0 Members, 0 Anonymous, 1650 Guests (See full list)
