Ascendant Audio Smd 18" Blowthough In Standard Cab S10
Bumpindemlowzz
I am soon hoping to put a blow though in my 97 standard cab s10 but i need help with what amplifier, how many batteries i should go with and alternators... The sub would be the new Ascendant Audio SMD 18" as what indicated in title which comes out next soon.
Here are some pictures of what i would like to do.
Posted Image
Posted Image
Posted Image
Posted Image
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
since nobody really knows the final results of the sub its foing to be real hard to give you some solid help on that sub. As for all your other questions they can be answered with some searching.
2 extra batts and a 200 amp alt would be ok for 3000-4500 watts, how does that box sound?
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
imo i think there would be some serious box flex on the wood infront of the sub. i might be wrong though
for a woofer of that scale, I see to many flaws in that box
Would that box i think ill double up on the mdf. I have no idea how it would sound but for my situation i think its my only option...
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Since this woofers is gonna be upwards of 80lbs I would double layer the woofer mounting baffle and definitely use t-nuts and allenhead bolts, as well as double layer the piece the woofer will be firing into.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
its never your only option,
how are you calculating tuning on it?
All those differences in air exiting is sure to be a wierd tuning
another thing, Iam sure that SMD sub is more than 12" deep, just a guess
so you will have to compensate for wood thickness, and woofer depth
and like Will said, to atleast double layer the MDF/Wood where the sub will be mounted at
  • Who's Online   0 Members, 0 Anonymous, 8972 Guests (See full list)
