IIRC the knob twists counter clockwise from 0db to full tilt
thanks!!...that was the answer i was looking for..thanks bro!
You guys realize that these are bass "reduction" knobs right? They don't offer any gain.
They go from 0 db to -12db.
I have one in my PT.
**Edit: I use it for when the playstation is on, to turn the subs down.
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
are you serious?..wow!..i was just about to order it right now...
^^ no, any knob you buy that runs thru rca cords will take whatever your amp does at full tilt, and turn it down.
There will be no gain, all they are is a way to controle the volume as if you where using the subwoofer preout feature on the headunit.
I personally wouldnt trust any sort of knob that has freq control that runs thru the rca's.
I also used a pherpiheral prc -1 for about 2 years until the knob wore out, got massive static sounds when turning the knob. It also turned really hard in cold weather.
You will not get a REAL remote bass knob for any amp unless the amp was made for a remote by the factory.
All these other knobs will just reduce your headunits preamp output voltage from full to none.
so is better if i get an amp that comes with a bass knob?...i guess ima have to do that...thanks for all the help
why not post this in the right section too?? like gen audio :rolleyes:
NoFearX18 said:
trainman0978 said:
