2000lade's Demo/bassrace 12 15" Mojos
try different amps?
R.I.P!
(Nov-29-2009)
92 explorer
current build
I dunno man...I still stick with my original plan....something with the batts. The fact that you get about the same amount of wattage out no matter how many amps/subs are hooked up tells me that your limiting factor is input current. I hope all works out for you. I'll stop bothering you now.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
i dont want to sound like a smart ass but u try throwin a cap in there to see what the diff is? i put one in my geo after i done the big three n i went from 14.4 to 14.10v and voltage will drop when cars off but goes back to 12v, ied try one for the hell of it, n just wonderd but what voltage would u get if u wired a 12v in parallel with a 16v? anyways dunno what would be the prob just maby try more runs of 1/0 to front battery? atleast 3? or a run of pos n neg to front but i think u already done that tho ied try another run of 1/0 to see if that helps?
you do realize that 14.4 is a higher voltage than 14.10? that means the cap hurt your voltage. lol
Have you clamped the amps input to see what kind of current they are drawing?
What about input voltage at the amps terminals?
Check all your battery's terminals and make sure they are tight and making good contact.
Are you taking voltage measurements at different points on the bank? This will help tell you if there is a bad connection somewhere.
One thing I did notice was that you have each bank of 7 batts connected by only one piece of 1/0(+ and -)...that could be a choking point especially if all your amps are only connected to the rear-most bank.
If I think of anything else I'll chime back in.
That is the only thing that I can see problematic, I would try running more than one run of 1/0. I'm only running 4800 watts and using 4/0 to my batts. I always think overkill is better than just enough. Don't know if you tried this all ready but just trying to help.
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
as said, one run of 1/0 is only good for 3000-3500rms. you wont really get 4800 with only one run, maybe 2/0 you will.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
the damn 1/0 wire is NOT the problem. as stated, all those batteries should be able to power 2 amps for 3 seconds. (i think he said he tried 2) theres no reason why it shouldnt.
calm down ChevyBoy. let's all take sip of "calm down". regardless i hope he finds the problem soon because i see nothing but greatness out of this build.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
When your voltage drops to 10 volts, is that its lowest it goes, or do the amps shut off?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
yup we did idea 2 and now we dont have any amp problems!!!!!! that parts fixed now we are seeing 1000w per sub.
im very happy now. now we are going to play with the tuning.
thank the lord my voltage drop isnt that bad anymore. drops to like 12v now
