if your port is on the same plane as your subs yes it will but if its not no it wont. it would only add 3/4" to ur port length even if it was. not enough to really change your tuning much.
your addung to outside so no depending on box arangement
x2
if you have a slot vent on the sub mounting plane you will add .75" of port depth, which depending on your specs probably wont be noticeable.
-Drew
uhoh_45 said:
.75 of an inch isnt much either you would not even notice it if it did change your tuning
R.I.P!
(Nov-29-2009)
92 explorer
current build
HAHAHA almost the exact same post at the same time FTW
-Drew
I added a second baffle which also affected my port and it didnt change any tuning really.
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
ill go out on a whim and say almost everyone on here has a box 16 cubes or less... this is the majority (dont chime in if ur bigger)
with that in mind... the most .75" added to port length will change is .3hz, depends on surface area but that just gives you an idea of how hard it would be to "hear" the difference
