zx1500.1 wired to 2 ohms
hadn't had a problem with it, got it probably 2 months ago, haven't even gotten it warm then today driving, bam, protect....
i was like wtf mate!?!?!? amp was cool, i would say barely warm
gains are set properly, under half, voltage was right over 14... i wanna say 14.2ish
here's when it happens, and it does everytime i do this...
if i put my bass boost knob up over +-1/4 it goes into protect
if i keep it off it works fine... only thing on kicker amps if bass boost is off there is little to none output
so to keep it out of protect everything has to be damn near off
i checked the owners manual, doesn't list the possibilities of why it would go into protect, i unpluged the power and put it back it
like i said it happened outta the blue :unknw:
i tried to sum everything up ha, if you guys need to know anything else i'll fill you in, i can take vids tomorrow if you'd like, just let me know
thanks,
austin
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
You got a broke amp or a loose wire or a popped coil. Those are the only things that I can think of that would cause that.
Last thought, are you sure you got the subs wired right???
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
check the ground and power wires.. coulda came loose or something
you ain't been bizzy til you've been wit jizzy.
Vehicle:: 2005 Saturn Ion
Headunit:: Jensen 9312HD
Speakers:: RE SE Coaxials
Subwoofer(s):: (2) 15" RE SEs
Amplifier(s):: Audiopipe AP1500.1D
Audiopipe AP1504
Enclosure:: Sealed
Wire: KNU KONCEPTZ 1/0
Battery:: Kinetik HC600
i was wondering bout something in the sub, the coil is going out, like sub is almost ready to be used as a paper weight or try to get it reconed
it's wired correctly but the coil's burning up, you think that could have something to do with it?
the only wire that was even semi loose was the power which i reconected and checked all other conections
Alpine CDA-9883
Kicker ZX350.4
^^These are the first things that came to my mind.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
It is possible that you have popped one of the coils and the other still works, which would change your ohm load. Plus the coil that popped could be shorting out the amp. I have done that before. I could play it at a low volume and it would play fine but turn it up pass half way and it goes into protect.
Take the sub(s) out and check each voice coil to see whats what.
I do box designs.
Im guessing by one of his other posts, he thermaled the voice coil (prob from clipping).
http://www.stevemeadedesigns.com/board/ind...c=32389&hl=
hahaha i feel like a total newb but after reading, i've always noticed my sub putting off a potent smell, kinda sweet, idk i actually like how it smelt
but is this the voice coil or something else burning???
i am overpowering the sub, and when i smell it i turn everything down. I also noticed the smell mainly in the first two weeks, but even today i smelt it
Which then resulted in the below.
From one of his other posts here:
http://www.stevemeadedesigns.com/board/ind...c=33821&hl=
looked in there with a flashlight, vc looks black and the white tube piece that the copper wires are spun around looks like it has melted and bubbled
So now Im going to take a guess and this is what caused your amp to fry and be sent back and forth to Kicker 8+ times, according to the thread(s) below of your ranting about how you f**king hate kicker....
http://www.stevemeadedesigns.com/board/ind...c=29611&hl=
http://www.stevemeadedesigns.com/board/ind...c=30429&hl=
http://www.stevemeadedesigns.com/board/ind...c=30494&hl=
http://www.stevemeadedesigns.com/board/ind...c=31389&hl=
It seems tho you already knew your sub was bad a few weeks ago and posted videos and saying your coil looks "burnt and bubble", you continuted to use your car stereo, and now it made things worse to the point that your amp is kicking protect everytime you turn it up and cause a dead short from a blown voice coil. If you havent yet figured out someone thing is wrong and wanna continue playing it, I feel another 5 million thread comming from you about saying how kicker is bad, and you had it fixed blah blah blah and everything is fine cuz you checked it all out..
What you need to do, is buy a new sub and hook it up, and pray that you didnt damage your amp!!
awesome, it's for my single 15" L7, in the process of getting all new stuff cause the sub keeps fucking up ha
but before i take the sub out i should be able to just check the ohm load in the box terminals first? and if i get a funky reading then i'll take it out
i think this is the problem 95% sure
Alpine CDA-9883
Kicker ZX350.4
