I know i could still angle it but I kinda have a sponsor that said flat wall port to the driver side. A clamshell would give me a lil less cubes and make it work for 12s. If more than the 3 of you guys say clamshell then thats what ill work on tomorrow and see how my other half takes it lol.
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
You said that you have 32"X31" which is the width of the box? Because I don't honestly see you fitting 15's anyway with the width being the 32" even. The outside diameter of most 15's is over 16". So even if you put them right next to one another you will probably not make it fit. I say do the 12's in a flat wall. The flat wall is usually going to be better on the TL for numbers anyway. I'm not saying that a clam doesn't get loud, but why do most spl vehicles have flat walls? Because that's the loudest type of wall. Your going to lose some cone area and that may hurt a bit, but I really think you'll have quite a hard time fitting 15's in there. You may be able to fit them if you did a verticle clam and offset the woofers from one another, but that's the only way I see them fitting. Find out what the outside diameter of the subs are and let us know.
You could even do a 4th order with the 12's if you decide to go with them. The only problem with that is the limited bandwidth that you'll get from it. I don't think a 4th order would work for 15's due to the lack of box volume. You may be able to squeeze the 12's in there, but I'm not a band pass expert either.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Internals are 31.5 x 31. Thats not including if i have to use the outter parts of the box. I think its possible to do it! The trim panels will help it look better on the side. I cant read the link sent to me buy the sub company so i had to send an email to him about diameters
1997 2 Door Blazer
SBC/TH350
Well me and Joe were looking at specs and gonna do the 4-15" SPLX subs. I think i have more space between subs then he does haha. Ill have the inside of the box done tomorrow and hoepfully get the front baffle in and braced.
1997 2 Door Blazer
SBC/TH350
Why wouldnt it work? Joe has less space between subs then i will! So that would mean his wont work!
1997 2 Door Blazer
SBC/TH350
ok uhm where to start...... if it was me, and I really wanted to run 15's id rip out what you have.
4 15's are not gonna fit in what you have now, you have plenty of depth which imo is a good thing.
if you wanna keep up with Joe, your gonna have to come correct, and imo single layer shell is not gonna cut it.
you have 2 options imo, you can either yank that box out and start fresh or your gonna have to run 12s...
the front opening need to be bigger for 4 15s.
this is for music correct??
if so, I would clam it, clamshells have a fantastic track record for being fucking loud as hell and putting up big numbers in bassrace, dont let anyone try and fool you, Just look at frankie Rio's lexus when he took the drive by title he had a clamshell, ask Randy Kubiak Aka AssMan what he thinks of clamshells.... many loud ass clamshells out there...
and sponsors should have little say in how is built IMO.
