i say 2x4s or good sized all thread
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
Besides 2X4's and resin inside my box I also have 1 1/4" oak dowel rod bracing. Each of the three things that I used in my box have not failed yet and there is no flex when the subs play and very little echo when you hit the box.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
ive used them all, and am sticking with dowel rods
albeit small, the roughness of the allthread could cause more turbulence than a smooth rounded dowel rod, and ive found allthread works best when you have ~3X3" wood block on each side of its anchor points, otherwise the washer and bolts dent the wood when you tighten them on each side
and its not easy making a bolt sticking out of the box look nice, whereas the dowels are internal
nightshade: thats always one of my goals with bracing, if i can knock on the box and only get very high pitched short reverbs than you know the box's resonant frequency is well outside of the frequencies played by the sub
internal bracing is nice...but i like threaded rod as well. a lil more expensive, but i like the strength of it and the looks of it too actually. i think it gives it kind of an industrial look. you can see the nuts on the outside of my baffles and like it
Dude you like to wear your nuts on the outside of your baffle :01nocomment8so: Don't tell me that you wear them on the outside of your pants too :D
1 XS Power D3100
Audio Control LC6i
Stock Deck
  • Who's Online   0 Members, 0 Anonymous, 507 Guests (See full list)
