would pvc ports be any better then slot?
Maybe. You can make your own flared ports with pvc. All you need is a fairly large metal bowl that you can use to heat up the pvc with a heat gun and push it down over the backside of the metal bowl. You can continue to do that until it creates a flare at the end of the pvc. Now do that to both side and you've got yourself a homemade flared port. Or you could make a mold using mdf rings and bondo to make a flare if you want, but the metal bowl is the easier way to go.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
it would be regular pvc, if it works and i like it then i'll spend the money on aero's. you seem to have experience with round ports, how do they sound daily compaired to slot
recently ive been using slot ports for ease and its cheaper. i also dont have a large box so lengths of the ports get to be too long to be logical... but psp aeroports do work and sound verry good
if you do use regular pvc, double the wall of the box the ports are located on. mount them flush with the first piece. on the top piece use a router to make the holes, then use a 1/2" or 3/4" roundover bit to achieve a slight flare that will help if using pvc to give a more similar sound and spl u would have got with aeros
Do round ports sound any better than slot ports. I noticed a slightly smoother sound out of my last box with pvs ports vs my box now with a slot port. But Im not sure if this is a fair comparison since I doubled my cone area and my quadrupled my power.
Edited by Zade08
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
Typically a round psp will sound better than a slot port due to it having less port turbulence. Port turbulence is when the air is forced through too small of an opening causing a whistling or a muffled sound, and it will affect the sound quality and output of an enclosure.
1 XS Power D3100
Audio Control LC6i
Stock Deck
it will be 10cuft net with 144sqin of port. question is should i run a single 12x12 port, or 5 6in round ports?
Give us some more info. What is your goal for this box? spl or daily? What tuning? I recommend round ports no matter what but the goal of the system will help determine exactly how much port area should be used.
well i was wrong on the box size, it's going to be 12.4cuft after sub and port tuned to 36hz for a daily driver. but if the box doesnt work as good as my present box i'll i'll just go back to the original box. it'll will be a 200sqin port
Edited by loburbon
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
Round the ports like the box in the background of this picture
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
