ok well my subs are dual 1 so that gives me .5 or 2 ohm per subwoofer option.....if i do them both i would run it at 1 ohm
i want something that looks semi cool, stays cool and dosnt get hot too quick or anything, my electrical will be up to par first, 250 amp alt and 8+ batteries then adding another alternator down the road...im wanting at a minimum of 3500 watts per woofer, i would like to do 4000 watts per woofer, so far the dat hellfire 2500's strapped would be good giving me 3250 watts per woofer but im wanting more i think...im open to options and obviously dont want to spend a fortune but i know getting 8k watts rms isnt going to be cheap
so give me your options, i was looking at the memphis 4kw but ive been told there very power hungry...ill be taking everything into consideration, size isnt a problem
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
You can't strap Hellfire's to it unless you want 2 per sub.
Your only strapped load options are 0.5 and 2 ohms per amp.
Maybe a DD Z2LV? They do over 8kw @ 1 ohm @ 14.4v
Or 2 big 0.5 ohm stable-ish amps like AB VFL400.1/500.1, IA 40.1.
10.x volts fo' life!
2 Hellfire 2500.1 strapped would need to have a 2 ohm final load. Or you could do 1 amp per coil, 2 amps per sub 4 amps total
what about tk4's or two sundown 3000's per sub
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
i say run a dat amp per woof :-)
then bang it and if its STILL not enough grab two more later and do one per coil
-Drew
uhoh_45 said:
