yes, check my last post again
Eclipse cd7000
parallel is + to + and - to - of both speakers. This will lower the ohm load. in the case of 2) 4 ohm loads, it will half it. here is a formula
(R1 x R2) / (R1 + R2) = final ohm load
Now you can also do a series circuit. this is + of one sub to the amp, - of the other sub to the amp, then connect the remaining + and - together. This will result in the impedance being added together so in the case of 2) 4 ohm loads you have 8 ohms.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
if you had one single voice coil sub at 4 ohms and wired it up, it'd stay 4 ohms. wire another one in parallel, and it goes down to 2 ohms. wire it in series and it goes to 8 ohms.
thanks every1 for clearing that up i knew almost everything you guys said accept how the ohm load went up never knew that but my buddy didnt know any of it he thought if you had 2 4 ohm subs and you wired them to 1 channel it stayed 4 ohms so i had to clear that up with him
Guest KyleCannon
Just making sure, this also goes for speakers as well right? for example 6x9 with 5.25 both at 4 ohm in parallel will do 2ohm?
yes, it goes for speakers too.
It goes for any electrical load. like motors, resistors, light bulbs. its a basic rule of electricity.
Ed Lester
ShowtimeSPL Host
My old Build Log
Guest KyleCannon
Alright sweet! I just wanted to make sure before I fucked something up haha.
