Proper Way To Connect Battery Cable Lugs
What's the best way to connect 1/0 gauge battery cable to the lugs. Do you need a special tool?
This looks like a good price on a tool. Does it work well?
https://weldingsupply.securesites.com/cgi-b...:UNDEF:OR:04040
These are the lugs I have:
https://weldingsupply.securesites.com/cgi-b...weco+³Lug-Set²)
Thanks
Edited by rk772
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
yes
unless your engine is getting well over 400 (normal temps are 200-210)
and solder is like welding, vibration isnt an issue, and i will promise you a well done solder will work 5x better then a well done crimp any day, both in connectivity and strength
(i used to crimp, tried soldering, I'll never go back, you could tow a friggin car with 0g and soldered on terminals, most crimps i could pull off by hand with some elbow grease)
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
yes
I have the closed end lugs for the big 3. Can I just fill with pieces of rosin core solder, melt with a torch and then insert the cable end?
that wont work cause you have to bond the wire to the lugs, if you did that the wire would be cold, it would just create a cold solder joint.. That's why you need to heat up the lug with the wire in it first, then apply the solder.
Edited by wierdguy75
I use closed lugs and fill them about half way with solder then insert the wire. If you keep it nice and hot it works great.
  • Who's Online   1 Member, 0 Anonymous, 1164 Guests (See full list)
