ok I finally got a deck in the truck and the indaglo gauge over lay is causing tons of interference. Its on the same keyed power and ground as the deck. should i find a different power source or try moving the transformer box or something else?
1/8 inch plate of stainless steel over the transformer to act as a sheilder maybe? im not really sure, but you might just try moving some rcas around it helps a lot. they hate line current and especially tranformers even in a home setup.
:detective2:
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Not sure if the stainless would help, but they do use it around transformers and speakers because it doesnt let free electrons penetrate it otherwise try the power connection thing like chevy said but it could be an rca too close to an open splice
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
the rcas is a hole another issue all together i have them routed on the drivers side and all the battery stuff on the passengers side and it whines like mofo. Whats funny is i have my air compressor on the dis block for my amps. Every one said not to do it cause it will cause interference. well i did it and its not. i find that really odd. This truck is defiantly female
Most trans boxes for indiglo gauges throw some degree of whine NO MATTER WHAT.
-That is, I have NEVER seen/heard of a set that didn't have SOME degree of whine if you really pay super close attn to em.
I have an APC set in my Integra and its almost not noticeble w/ the car running and DEFINATELY NOT audible w/ the tunes goin but if I turn on my lights even to the ACC setting (the first setting where the dash lights up) I can hear a very faint whine from the trans box.
The only thing I have come up with is to isolate that trans box as much as possible and if possible completely seal it off from the outside world- as in, coat it in either resin or rubber material so it's friggin airtight-since noise travels through the air that should have some noise killing effect on it.
IF however the noise you hear is coming through the speakers, it's more like what Chris was saying and you need to seperate the rca's from that box by a bigger gap or more "material" in between them I.e. metal/foam/rubber etc w/.e. would make a decent space barrier or find a new place rout them so they are farther apart.
Hope that helps some.
Maybe I'll look further into a solution if you post that that was no help.
LMK.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
well I got rid of all the noise heres what I did. I put the power for both the deck and light to the keyed ingniton power wire. the constant power is still hooked to the deck aswell. I put the ground for both the light and the deck on the fire wall after sanding the fire wall to bare metal. The only problem now is when i role the power windows up and down the indiglo light turns on and off :lol:
  • Who's Online   0 Members, 0 Anonymous, 1424 Guests (See full list)
