another fuse is incase something shorts out on that peice of wire.. that way you dont ruin a alternator and whatever else might be touching that wire.. not to mention blowing up a battery...
fuse between the positive on the alt and the battery...
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
i was considering of doing that but then i thought about it if i do it right everything should be fine its not a thing that happens on a daily.. but if any of us were to fuse how big u think we should go? or it just depends?
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
I would fuse the wire to prevent the battery from blow up while driving. That would be so horrible to see the cars set up fire. Just use 300 amp fuse and you will be good. The big 3 very eazy to do if you got the knowledge and tools.
That's only If the wire grounds out, if that's the case your car will shut off. Happend to me in my crx when the battery post cam in contact with my air intake. Pretty much the same thing as something grounding the wire from my alt to my batt.
In my silverado, and my crx, there is virtually no way to some how cut through the insulation on my wire to cause it to ground.That would be my only fear to use a fuse. But I am also using welding wire, which also has a cardboard like material separating the outer insulation from the copper. Which I would suggest using because it's is rated for extreme heat. If your power cable were to rest on a hot surface on your engine it stands a better chance then CA cable.
I wouldn't fuse the alt to the batt. As you stated before, it's just to make you feel better. It's also always a good idea to have a digital voltage meter reading your voltage at all times.
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
