Torres' Box Tuning Calculator - Updated 8/18
Torres
Worst case scenario, just figure your net airspace and punch that straight in, bypass everything else.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
  • 3 weeks later...
Here, I mirrored it in my Dropbox for whoever needs it.
https://dl.dropboxusercontent.com/u/12084540/TorresBTC.rar
Thank you... I've been pulling my hair out for the last 15 minutes trying to find this program. I like to use this for it's simplicity, as it is about as accurate you are going to get. Then I play around with WINisd to figure out what different Vb's and tuning does to the output. Good little one two combo...
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
  • 3 months later...
wish it had a option for the cut sheet to include the angles need for a wedge box for my table saw. That would be ideal.!
Thanks Torres
That is where SketchUp comes in! Different horses for different courses.
Builds:
  • 1 year later...
  • 6 months later...
I'm using torres box calculator, with my sub box I would like to add three ports tuned at 33hz. The calculator does not give me dimensions on cut list for the ports, it states to complex to display. What should I set the diameter, 2 or 4 for best performance.
I'm going to assume you're trying to do three aero ports. So, guess what, you don't get a cut sheet for three plastic tubes that you buy and install yourself. Also, your port diameter will depend on what sub you're running, how many you're running, and how much power you're feeding it. I'm going to go ahead and say that three 4-inch ports probably isn't enough for what you're trying to do, as it's 36in^2 of port area. It'd be more efficient to run a single larger aeroport as well. More ports = less efficient
let us know what it is you have and want, and this forum will help you out.
  • Who's Online   0 Members, 0 Anonymous, 600 Guests (See full list)
