Torres' Box Tuning Calculator - Updated 8/18
Torres
the current one is able to do that, just fyi. i gotta get crackin on the update. i may upload it when finished then upload it again if/when i figure the printing issue with 64 bit windows so that way it doesn't hold up progress
can you write me a quick guide for calcs for 2 subs in cab with slot port either end.thank you.
just use the calculator and read the first post. he does everything but design the box for you.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
:deadhorse:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
^^ lol
ok, guide:
step 1: enter dimensions
step 2: enter bigger/smaller dimensions if needed
step 3: build the box
:peepwall:
^^ lol
ok, guide:
:peepwall:
can you repeat that but slower ?:lol:
2 12ks and i dont know what to do
build in the works!
Thanks for the reply guys I have been using this since the first version so I take your Wit with a smile.
What I normally do is calculate for one slot port of double width then split in half for 2 separate slot ports. The only way I see for multiple ports is using round ports. With slot port area filed in, if I then add to “# of ports” box my net volume increases rather than decreases I also lose the port volume and port area values, the tuning and port area per foot goes to zero. Port bend goes from yes to no.
# of ports is solely for aero ports. i have it so if that box is filled with a number, the length/width of the port gets taken out of effect. surface area of the port won't change tuning whether you have one port, or 5 ports with a slot port (the extra displacement of the wood for the port will cause an increase in tuning, however). you can manually adjust the port area for slot ports, so imo there's no need to use the # of ports for that. whereas for aero ports you have a set diameter, but can increase the number of ports used.
i hope that made sense lol
is there anyway to make this ipad friendly? only way im going to possibly be able to use it from my ipad would be to acess it from teamviewer which i still have to set up
NoFearX18 said:
trainman0978 said:
that's going to require a whole new program for me to code up. i'm working on getting to that point tho.
EDIT: i think i just finished this calculator tho. going to add the ability to change the background image/colors and upload it methinks. i'll still look into getting it to print on 64 bit windows still, just don't want that to be the only thing to hold it up
so...with a little research hopefully i'll be able to work on mobile versions :)
