Torres' Box Tuning Calculator - Updated 8/18
Torres
Any hope for an iOS/android version anytime soon? Use the iPad and Xoom way more than the net book anymore
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
soon as i finish coding this one, then those are my next projects to tackle. just this one last hurdle to cover and i'm good to go.
Torres, got a question for you re: aero ports
First, lovin' the calculator, it's what I used to design my current box and the results are wonderful. For that box I just did a slot port, but now I wanna do another box this time with aero ports. So I plugged in the numbers and this is what I have so far:
So my question is this, if my port length is 21" (7" each), why does it show my physical port length being 20.25? Shouldn't it be 18.75?
Also, when I add any length to the "length of external port" field, not only does it effect tuning, it also increases net volume the higher the value. Why is that?
Lastly, anytime the port dimensions "length" is larger than the depth of the box, "port bends" is yes instead of no. Does that any effect on internal volume or displacement calculations?
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
Thanks in advance for reading my post, so I can't come up with the same port displacement as your application calculates:
The port airspace displacement should be 14 x 3.5 x 32 = 1568 cubic inches.
The port wood displacement from 2 panels should be:
15 1/4 x 14 x 3/4 = 160.125 cubic inches.
11 3/4 x 14 x 3/4 = 123.375 cubic inches.
Adding all 3 you get = 1851.5 cubic inches or 1.07146 cubic feet. instead of 1.2 cubic feet.
I do come up with the same physical port length as your program states which has made things harder to figure out.
Hope you could comment on what is the difference between the two. Thanks again.
i'm wondering if you downloaded that specific calculator before i spotted (or was pointed out to me) a flaw in the coding. i put in the same measurements and i'm getting a port volume of 1.04, which is 3/100 off of your results. i'll double check the coding next time i have time to work on it and see if i can find any flaws
i just downloaded a fresh version of the calculator off your skydrive, last update was 7/14/2011.
put those numbers in and i get 1.2 cu ft for port volume as well
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
wtf?? maybe i fixed it but haven't been able to upload it due to the current updates i'm working on since the one i tested on isn't uploaded yet. i was supposed to go to another christmas dinner tonight, but haven't heard back yet. so maybe i'll get crackin on it right now
