USLESS Posted February 24, 2009 Report Posted February 24, 2009 can someone tell me the math formula is for enclosure and port area. i forgot it. my 94 ranger build http://www.stevemead...4-ranger-build/
Jensen Posted February 24, 2009 Report Posted February 24, 2009 http://www.the12volt.com/caraudio/boxcalcs.asp I found this the other day I hope it helps
IAMBUMP Posted February 24, 2009 Report Posted February 24, 2009 or someone could just tell him, as the one on JL's site is in the worst possible lay out ever. hell, it doesnt even solve for port length, only fq. so you have to rearrange that formula to even start to think about solving for port length. If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
USLESS Posted February 24, 2009 Author Report Posted February 24, 2009 search, or use google i hope you all the luck with your amp company and thanks for your unusful comment. :censored: my 94 ranger build http://www.stevemead...4-ranger-build/
Torres Posted February 24, 2009 Report Posted February 24, 2009 i have a link to a box calculator i made in my sig if that's what you're needing
Neo_frog Posted February 24, 2009 Report Posted February 24, 2009 This was the first site that came up with "box port equation" in Google. http://www.ajdesigner.com/phpsubwoofervent...th_equation.php And this is SMD search... http://www.stevemeadedesigns.com/board/ind...l=port+equation You can't rely on everybody to just do your research. Took me all but 30 seconds. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
