My Kenwood Amp Gets Hot =/
Jeep03
Messing with amp settings wont help it.
You need to wire your subs to a 2ohm load on the amp, if they are single coil 4ohm sub's: are these the ones you have? http://www.bestbuy.com/site/olspage.jsp?sk...d=1166840602883
If so youll need to wire them just like this.
Posted Image
great point, i total forgot about that possibility
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
no matter what you do its the amp plain and simple... i know people who have used it and once it gets super hot like that it dosnt matter if you run it at 4 ohms or anything, its all downhill from here...the kac series kenwood amps are just not that great
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
or it could be the user
DC.jpgDC POWER
Dam i dont have them wired that way.. so ima have to take out the speakers and wire them and connect them together Positive with positive and negative with negative through the inside of the box? and haveing only 1 connection from the outside being used.. correct? basically like bridgeing them.. cuz this amp has it be able to be bridged.. I just connected them with 2 differend wires ill post a pic up right now.. hold up
when i turn the settings down its just warm. and not mega hot like is now. Ima try what he said and see if it works tomorrow when i get out of school btw heres the settings:
Posted Image
Heres the fans:
Posted Image
The wires on how they are setup atm:
Posted Image
Posted Image
Right Side Speaker:
Posted Image
Left Side Speaker:
Posted Image
  • Who's Online   0 Members, 0 Anonymous, 724 Guests (See full list)
