I have a friend who has a very unique request. He has a G Wagon and needs his cargo space. So I thought about the Rodeo rear speakers which are mounted on the roof. We are working with two 8" shallow pioneers. Obviously not trying to knock pictures off the walls. Any suggestions?
Lot's of creativity will be a must to pull this off man.
Not saying it's not doable, it's just you'll have your work cut out for you to make it right and look good.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
I would build a box for a single 10 down firing, ported. I would not take up to much room at all and you can still pile stuff on it.
DC.jpgDC POWER
ok not sure how these look in the inside but see if its possible to tuck them into a cubby of open area along the sides could glass a couple boxes in pull em out wrap in the same material that way it can also be put back to stock if need be also looks real nice in the car maybe try and put a cover panel over the sub as well as to hide them and also look stock
must be nice huh
roof mounted eh? i would do what stephen said, down firing box ported ftw in that event
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
i had this idea years back...i wanted a roof console with 3 10s in it, in a F250. Doubt it will ever happen but man it would be cool! good luck, charge accordingly!
2007 Acura TSX
Stock Navigation
Rockford 360.2 (FOR SALE)
Sundown SAZ3500
2 12" DC Sound Lab LvL4 @2ohm
JL 600/4
2 Sets of Focal 165K2P
Didn't really think abount downfire. Funny thing is the last two boxes I built were downfire,LOL. He piles a lot of rims and other car parts back there so I'll run that by him and see what he says. Thanks for the suggestions and comments.
its silly, but we did it in a t-rex and a lotus a while back
fiberglass the front part of the passenger foot well and run a single 10 or 12, sealed or ported...basically whatever fits, and run a beefy grill over it.
one got a jl w3 with the nice jl mesh grille, the other was an l5 with that beefy ass kicker grille.
its outta the way, sounds great, and unless his girl is 6 feet tall noone will ever be bothered by it, plus wrap it in whatever carpet matches the floor and it looks perfect
The most i've done is mount the amps for our shop truck to the roof (regularly filled to the brim with parts), andd did a single 15 in a small box with a banana plug, with the wire run out of an acess panel, took like 4 seconds to put in or take out.
basically welded box steel to the b and c pillars (2 door truck, so middle and rear), connected it with some thin tubing, and ran two straight across in the rear, right where we could bolt through the feet of the amp into the tubing. run some wires, put some headliner back up, voila.
Team DC
Raytard...I like that footwell idea. I going to look at the truck again and see if that is possible. He considers this to be his work truck, so I don't think he has many people riding with him anyway. Good Looking Out!!!
