Nice little tutorial for those having the same problem.
Good job mang.
Thanks man. Id love to learn to work on these things myself. Got a lot to learn though.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
the bottom plate is somewhat flexable, so i can see this happening depending on where and how you mount the amps, and the material under it. could be a mounting point thats an uneven surface, or thick material pushing up on the bottom plate while mounted
decent fix, altho I think your problem will reoccur pretty soon.
Electrical tape aint nothing to thick and if you had problems with rubbing before, its still going to be there and just rub thru the tape.
My spl amps have some sort of thicker heat resistant pad it looks like that is really stiff and some what thick. Or use something more absorbant such as sound deadening material (perferbly something without a metal backing like black hush mat).
Ya I still need to go to the hardware store and get a different material. Te electrical tape was just a quick fix. Ima look around a bit and update wit what I find and how it works out.
Why wouldnt you un hook all of the wires like remote, power and ground at least before opening up an amplifier?
I undid my fuse at the front bat as its easier than disconnecting all the wires.
Get you some rubber tube patces and glue them to the cover.
Sundown SAZ-3000
2 12" T3 DVC1ohm subs
58hz peak cabin frequency no deadner yet
box tuned to 38hz
BIG 3 upgrade
yamaha patio speakers rear fill
Alpine 9833 deck
PPI FRX-456 Crossover
PPI PAR-245 Preamp/EQ
PPI DEQ-30 Band EQ fronts
PPI tweets in kick panel
PPI 2-way's in kicks for now
0/GA 1 run front to back
Memphis 4 channel running rear speakers 75 X 4 only 2 channels used for now
Planet Audio 4 channel 75 X 4 running front speakers
146.7 db usaci drivers door open
163.3 db port challenge mic in port
2012 4door silverado
  • 4 months later...
Just like to bump and say Thanks to Zade08 for saving me a lot of frustration :good:
-Drew
uhoh_45 said:
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
