Bracing Or Double Thick Walls?
Getting ready to build my wall for 2 18" btls....got a quick question. 10cuft box tuned to 35. Should i use 1.5" walls all the way around or should i be fine by bracing it all over?
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
you can never g owrong with more.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
the only problem with doing the 1.5" walls all the way around is that i drop from 12cuft to 10cuft.... how are the btls going to sound with only 5cuft each?
Systemless.
only use 1 layer if you use Birch and you have strong steel bracing to eliminate flex, otherwise, go multi layers.
I build my walls with 4 layers of .75 minimum.
There is gonna be alot of pressure with 2 18s and it will flex even 2 layers braced.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
