I got a couple 5 gallon tanks and a 9 switch box..
http://sfbay.craigslist.org/sby/pts/1184634760.html
Edited by dunkoholic
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
That durango has coil springs all the way around if i remember right. measure your spring pockets and see how big a bag you can fit (hopefully at least a 7") and get bags/cups for the whole truck. they prob don't make a full bolt on kit but you can fab something.
try air rid technologies, they have bolt on kits for alot of applications but they rarely lay all the way out since there is minimal cutting involved.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
your not going to lay out with a "kit" if you can even come across one. your gunna need a 4 link, you dont just use what you have when you bag things. if you want to lay out fully i suggest you read....a lot. and look at a ton of pictures of your truck and the work done to it. If you want to just sit on the tires i guess you could do that...
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
Cool thanx all! im not tryin to drop it to to low, I basically just want to have some other aspect to play with and show off! im putting a huge system in My durango, so i'll be needing a new suspension anyways.... I figured there really wouldnt be an easy bolt on kit, But I cant weld and I was hopeing to still be able to do it all on my own!!
suicidedoors is an awesome company, so is avsontheweb.com with a kit its hard to get exactly what u want, its usually better/cheaper getting on one of the mentioned websites and buying everything seperate, that way u can have exactly what u want
  • Who's Online   0 Members, 0 Anonymous, 1842 Guests (See full list)
