Working With Plexiglass, Question.
i tried it and looks like i have to pre drill the hole bigger than the screw it self because the screw doesn't seem to bite in the plexi(and its making a bad sound as if it was cracking).
i'm thinking of just using a silicone caulk to seal it up tight.
the edges will be hidden because i'll put another beauty panel to cover it up.
btw i used a normal drill bit and it seemed to work fine no problems at all.
i also used a normal counter sink bit and it worked.
Edited by kentb
yea iv made a small practice box ans used plexi, and all i did was pre cut 6 screws to hold it to the mdf then siloconed it, and was AIR TIGHT!!! held water without leaking. so that would work..
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
Yeah, you want the holes to bigger than the OD of the screws your using. You don't want to be screwing into the plexi. Regular drills work fine on it the first time through, if the holes need to be opened up, when you try to re-drill the hole the drill will grab and might crack the plexi or your wrist...whatever one is weaker... :rofl:
"I don't bullshit. I do what I say & say what I mean."
http://www.cardomain.com/ride/2925230
http://www.armoredhaulin.com
unless you're REALLY careful...which i would be.
ei man where the hell are the vids of your system????????????
Silicone would work, but I wouldn't use it for the plain fact that if you ever want to open it back up for anything it'll just be a pain in the ass to separate the two. And also now you've got silicone fumes in there with your subs eating away the glue on the subs.
Just go with the weatherstripping and be safe then sorry.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
