My Son Just Made My Night...
This should be a sticky! it's awesome to see a father and son getting to share an interest in something and do it together. Go for it little man, start savin your money and by 12 who knows what awesome systems you'll be building :D
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
AWESOME! Only concern is the 2" port is gonna cause some noise but its not like you cant refigure later and put a wider one in as long as there is room.
I talked to him about maybe doing one big port, but to be honest I wast sure what size port to use if we went with a single one. Here's my math...So as stated we are going with 2 2'"x6" ports ( w x l) so we should be able to use a single port with a size of 4" x 6" and get the same results correct? Also would this lessen our chance for port noise?
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
honestly it depends on what you want to be tuned to ...
Edit after some quick calculations your gonna be tuned around 47hz
If you do one 4"port for that same result your gonna need 11.96 for your length to get the desired frequency
4x6 would tune you around 61 hz
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
All the specs are saying 42, but I have never built a box for 8's so I am unsure how low I can set them..
2 2X6's are the exact same port area as 1 4X6" port. With the 4X6 you'll probably need to make it longer to compensate for being larger overall. Where do you want the tuning to be? Give me the box size and what tuning you want and I'll tell you exactly how long it needs to be with a 4X6" port.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
and just a rule of thunb for me i try not to go any smaller than 3" port for 8" drivers. Its not car audio law just my own practice :)
Scientia est Vox
42 hz k cool
I think he wanted to do circle ports still and he was talking added the 2 2" port sizes to get the 4" figure but anytime you change port width the length is also gonna change for 42hz the port length would have to be in the ball park of EDIT 16.27"long I need coffee :shok:
Scientia est Vox
This is so cool. I am tuned into this topic. Your box will look good when you are done lil man!
No matter how hot she is, someone, somewhere, is sick of her shit.
99 Tahoe:
2-10" MA Audio
4-6.5" Kenwood door speakers
Total Amp
Sony HU
42 hz k cool
Gotcha. Yeah I would rather see some circle ports in there anyway. I do also agree with you Roscoe on at least going with a 3" or larger port. If they did 2 3" ports it would be 9.42sqin per cuft and is a pretty nice amount of port to box size. That is if I'm correct in assuming that the box is going to be 1.5 cubes.
1 XS Power D3100
Audio Control LC6i
Stock Deck
