Brandon's Need For 2ohm Stable
BIG-SEXY AUDIO
As a few of you mite have already read in some of the other topics, I current working on my buddies system. BIG-SEXY AUDIO went to the show this weekend, and I brought home 1st and 2nd. The guy that won first have the money right now to step his game up by doubling his system, now I could either run to amps (they'll never have the same power pull,close but not the same) or I could wire 2 2ohm in series/parr which would give me a 2ohm setup. So what I'd like from all of you is tell me (other than Kicker, cause I already know that one) where and who makes 2 ohm amps, I need aleast 2k RMS amp.
Brandon NOW
 2005 Kicker D2 L7 15"
 2005 Hifonics BXI1206 @ 1ohm
 All RF wire (4g power, 8g speaker, ready for 0g)
 Enclosure 5.5 @ 40-42
 RedTop
 140.8(show score) 141.2 (after RF wire)
Brandon LATER
 2x 2005 Kicker D2 L7 15"
 Amp????
 Stringer 0g power, Stringer 8g speaker
 Enclosure 10cubes @ 38Hz
 Dual RedTops
 He wants a 144dB, so he can BassBox someone
Just need an amp.
I have this dream of this underground culture in mind, coming to life through the Audio that I build, Deep Perfection.YUKON'S SITEhttp://www.cardomain.com/ride/2397609
if you want to stay kicker.... colossus more power
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
kinda a no brainer answer = kicker zx2500.1
definately go with this one.  it be a perfect match.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
T15002, T20001bd, T30001bd. The birthsheets i have seen for the t15002 have been right around 2kw when bridged at 2ohms, and most of the t20001bd's i have seen have been about 2kw at 2ohms too, but if you want to go with the rated at 2kw at 2ohms then a t30001bd would do that.  Sorry i have always messed with rf amps.
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
Well he brought me the new sub tonight, I just went and bought all my materials. 2 MDF sheets, 5lb Screws, Wood Filler, Bondo, Resin, 60-80-120g sandpaper, etc etc. Took out my pen and started planning. 12.75 cubes @ 38Hz, Dual RedTops, 0gauge runs, 8gauge S-wire. The Amp which is this subject he WANTS (doesn't have too, just wants) to stay with HiFonics amps, hi/mids/lows, the whole setup. See I need something so when we go compete, I can turn it on up, and bring it out of safe mode into extreme. So I need 2k RMS rated, the Hifonic BX1205D pushes over 1.2k itselfs, I's like to double that. That is the whole reason for doing this is to double eveything.
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
