I will send $40 to anyone who can tell me how to reset my Airbag light that keeps flashing in my instrument panel.
It's a 2006 Nissan Altima...YES, I disconnected the plug for the passenger light under the climate control and I know thats it needs to be reset now. (I was installing the Alpine processor that dcexplorer asked me to "Take a second" to install to see if it worked...in my rush I forgot you can't unplug that lite)
Already tried disconnecting the battery...that didn't work.
If you can tell me how (Other then telling me to go to the dealer..errrr) AND your method works I will shoot $40 into your paypal account. :8)
Disconnected lite under these controls.....
Now this lite contiually flashes....
Worth a try but am unsure if it will work.....try taking it to advance auto and have them read it with the OBDII reader and see if it throws a code and if it does just have them clear it.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
yeah you have to have it cleared with a reader i worked at a body shop we had to take newer cars to the dealership to get codes cleared
Roseville, CA
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
no bs either try it
Edited by troy
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
TJ, try disconnecting the batt and letting it sit for about an hour, then re connect.
un hook the airbag light ftmfw!? :01nocomment8so: :unknw: :tease: :8)
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Actually swapped my battery out the other night and my ground didn't reach the new battery post (Odyssey 2150) so It was disconnected for about 12 hours until I could run a new ground. Thanks though.... :8)
no bs either try it
this will work ive done it before myself
This topic is now closed to further replies.
