i just installed my new stereo and i was cruzing and bumping and i put sum jeeezy and all of a sudden the subs wernt as loud as they were they got more quieter then before. and now for sum reason my subs dotn sound as loud as they should?would say if the back of the rcas not in tight be the problem?i have pioneer deh-p7800mp
anybody know?
rcas could be the problem yes. so could 100 other things
like what else casue this has been getting me mad all day,cause i have the pre harness ones and i dont think i pressed it in that hard would that be one of the problems?
Posted (edited)
push it in better and see if that fixes it, also if you use spade connectors to connect the speaker wires to your subs one of the voice coils may have come undone, i kept having this problem with mine till i soldered them... i dunno what gear you have so thats all i got for now...
Edited by bobo333
^^^ clicky pics for build logs ^^^
Posted (edited)
do you have front/rear/sub output from your head unit? *i dont know if yours does or not* but i know my subwoofer output went out on mine and i had to use my rears for it to bang again.. till i can replace my headunit
*edit* mine didnt fully go out, it still pushed a little tiny amount of bass thru it but it was really quiet.. try switching your RCAs to your rear output tho
Edited by Army_guy614
Team_DC-Derrick's Youtube
Team DC Audio
Posted (edited)
if you have a pioneer stereo , try grounding one of the rca's outer shield on the deck .
Edited by n-stereo
McCain Mobile Audio
4x world champion
3x world record holder
Take the subs out of the box and check each coil to make sure that they are still good. Also check the tinsel leads on the subs to make sure that they didn't break or burn. I've seen that happen before where the subs will get quieter because one of the leads broke on the woofer leaving only one sub playing. You don't actually have to take the subs out if you just use a dmm and check the impedence at the amp and if it's wrong then take out the subs and see if there's a problem. I just usually go right to taking them out cause I don't mind doing the work.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
okay so now when i take off the remote bass gain off the subs make like a weird noise and it's like as if the gain is up loud but it's not.and then when i take off the rcas off the back the weird noise is gone??and how would you ground the pre out harness of a pioneer?
did you try switching your rcas from subwoofer to rears on your head unit like i suggested?
Team DC Audio
