Exposing Amps To Pressure...
Neo_frog
Is it a bad idea to expose amps to 160dB of pressure? I noticed Neil Barber has some of the amps as his center console for the highs and he runs them during his bassrace runs.
The reason I ask is because some ideas I'm having for the next build require my four channel amps to be in the cab mounted behind glass as part of the center console, but if it's going to risk messing them up, I don't want to do it.
Let me know what you think!
Need an install? Hit me up.
[email protected]
shouldnt be a problem.
I have exposed many PCBs to over 160 dB and no issues have arisen.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
I dont think the pressure is so much of an issue as vibration, there really isnt anything in there that would be crushed by that kind of air pressure, but the vibrations would probably be bad (even at 130db if the amps are close enough to the subs/on the box/on something flexing it can cause damage)
so, as long as its mounted to something not vibrating/flexing it should be fine imo
Team DC
honestly every amp ive ever had has been mounted to the box and ive never had issues with vibrations...
and theres not THAT much pressure inside the vehicle...yes its a lot to humans but really its around 170-180 when its starts to be considered 1 PSI which im sure the parts can handle that pressure
NoFearX18 said:
trainman0978 said:
Excellent. My plan is obviously to deaden the surface I'm building for it so there's minimal vibration so I guess I'll just follow through with the plan.
[email protected]
