im wanting to do a wall, something easy yet practical, its basically going to be 1 big box, with trim panels around it to help make it airtight and look good, im having problems on deciding a sub/port config, im wanting numbers but im not wanting a burp machine...this is in a daily driver and will be ment to play loud all day and still put up a good number
whats the best configuration i should do? its in a 2004 f150 ext cab
both subs on top behind each headrest port on the bottom
port drivers side, subs ontop of eachother passenger
port passengers side, subs ontop of eachother driver
both subs on bottom side by side, port top
not sure! calling all wall guys haha!! im thinking 35hz tuning if you have pictures post them!
Edited by loganberry
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
so far subs on pass side and port behind the drivers seat is the loudest in my truck.
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
Wiring-Memphis
Honestly, anything goes. It all depends on tuning, type of car, type of box, subs, amps, etc...
So far, what works the best as far as SPL is subs on passenger side and port on driver's side.
Don't limit is to your choices though. You could get two more and get creative. Just make sure you make the enclosure really strong and compensate your size to include bracing so you don't affect your tuning.
Need an install? Hit me up.
[email protected]
i think the subs on 1 side and port on the other side dont look right for a daily driver/pounder.
when you going to build and where?
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
when its being built is being kept on the downlow but for team members, its 2 dc sound lab level 5 15"s on 1 stetsom 7kd, it is a daily driver, i want it to play almost everything tuning wise but dont want something so low it meters like shit, plus the wall should help cut down on flex, only was able to do a 146 and change, this flex is hurting me bad so its wall time
My F-150 Build
ehh fuck the numbers! wall it for the :hairtrick: :hairtrick:
8 - Re SE 12"s
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
can anyone explain to me how subs on passenger and port on driver is generally louder, to be honest i thought it should be the opposite, meter is on passenger side so shouldnt the port be? im not doubting you guys thats how most people do it, but just wondering why
My F-150 Build
what are your dimensions
R.I.P!
(Nov-29-2009)
92 explorer
current build
