Well then...
Unless theres not enough power on the remote to turn the amp on which is doubtful. The only other thing it could be is the headunit preout is bad.
You could check all battery connections to make sure they are tight and theres no coriossion.
You could also jump the remote wire directly to the constant power on the amp (if amp plays fine your problem is the remote, if it acts the same then the remote wire is not the problem).
If its a pioneer headunit, or even another brand, try grounding out the rca cables.
try a different pair of rca's. this has happened to me before and it was my rca's.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
by grounding the rcas i just wrap wire around the barrel of them and screw the wire down on the hu right???
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
yup
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
I remember on my old system my subs would "poof out". It turns out the problem was the amp had a bassboost switch and somehow mine got set to the "middle" so it was acting weird.
I would be leaning toward bad RCA's. Try hooking up a LOC (line output converter) to see if the same thing happens. A LOC would eliminate bad preouts or confirm bad RCA's
My bad. I just read where you switched RCA's. Still I would try a LOC to rule out bad preouts
Edited by jsmoke222000
Jared Nixon  A.K.A. Jsmoke
My Car Stereo Website: 3rd Coast Customs
My Fishing Website: BigLake411.com
Add me as a friend: Myspace
Download: Check out my Audio Calculations Spreadsheet (Microsoft Excel)
ATTENTION ALL SMD MEMBERS: Do not under any circumstance buy anything from Chassistech! They do not stand behind their products & their customer service is horrible. They do not actually manufacture lowering springs, they drop ship them from Spring Tech. Chasistech.com also does business as Airbagit.com, Streetridepro.com & Truckinsuspension.com. They are all the same company! Do not trust these bastards! Their products are cheap & more often than not, you don't get what you actually order in the first place! YOU HAVE BEEN WARNED!
bad rca signal.
ground them real good because you have a pioneer.
pioneers are notorious for this.
yeah i'd try grounding the rcas, happened to me on my pioneer, they wouldn't go to full excursion though, but they moved a lot. very slowly.. also wondering if you've thrown another amp on that signal, and did it do the same thing, i know you said you put that amp in another car, but did you put another amp on that setup.
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
As the others have said, switch out bits to find the faulty part. I'm betting on a bad amp.
The older class D designs had a very simple output filter to get rid of the harmonics kicked out by the switching process. If the capacitance of the caps in the filter changes significantly (heat, age etc.), it's common for a resonance to build up in the filter, causing the problem you describe.
  • Who's Online   1 Member, 0 Anonymous, 1811 Guests (See full list)
