Last time I saw subs pulsing like you described, it was because gains were all the way up on the amps, line drivers, and head unit. The amps were perfectly fine, but moved the subs exactly how you were saying.
Need an install? Hit me up.
[email protected]
last time i had seen that the rcas were pinched and giving a bad feed
R.I.P!
(Nov-29-2009)
92 explorer
current build
had the same happen to me but on my T30001bd where the sub just moved up and down very slowly even with gains on low however i just flicked the Infrasonic Filter to the on postion and it stopped may be check the infrasonic filter on yours ??
As the others have said, switch out bits to find the faulty part. I'm betting on a bad amp.
The older class D designs had a very simple output filter to get rid of the harmonics kicked out by the switching process. If the capacitance of the caps in the filter changes significantly (heat, age etc.), it's common for a resonance to build up in the filter, causing the problem you describe.
It's a 2 channel Kenwood, hence I'd be willing to bet it's not Class D :)
10.x volts fo' life!
no most definaely not a class d.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
no.
^^^^^^its not a fn pipe man. you can't scrape the reson off and get high. lol.
Uh, he's actually correct. Class D amps use a low-pass filter (aka crossover) after the output section to remove the extremely high frequency PWM carrier signal.
Most new ones just use an inductor but some old ones had a bipolar cap to increase the order of the crossover and if it goes faulty you can get oscillation in the filter. That's a form of RESONANCE. RESONance not RESIN. Gah.
geez. somebody got no since of humor man.
This guy is looking for answers not comedy....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
