well, i went to wal-mart yesterday, and when i went to start my car, it...well....gave a brief hick-up, then i shut it off immediately. When i went to restart it, i could feel the starter engage, but the crank would only turn bout 1/2" before turning back to resting state. :censored: car is a 97 escort 180k miles, junkyard motor with 70k on it *replaced when car had 150k)* replaced timing belt when we put j/y engine in. Right now i'm thinking it is the starter because i have plenty of batt power, and i kinda doubt it jumped time and got really f'd up (or at least i pray so) due to the new timing belt. oil just changed bout 1k miles ago and it was clean (no metal shavings) Also, about 6 months ago the starter would make a funny noise when it disengaged. So, unless you guys have any other suggestions i'm gonna make a run for harbor freight to get a floorjack and a pair of jackstands and gonna have to pull the starter in the school parking lot, and start things from there. :help: not to mention i have hardly any time since finals are coming up quick :shot: any help would be greatly appreciated, as i'm not the most experienced mechanic but i do have some experience under my belt
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
something like that happend to me yesterday, but to find out it was my ground wire on the batt.. it came alittle loose
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
checkall your connections first. avoid the little htings. you can also look and see if the teeth on the starter are screwed up. try the ole hammer trick as well.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
im all about lending a hand if i can, but being you are in florida and i reside in pa causes some issues. and i am a ford person, dont like to pay overseas venders for services that are just as much quality made by our own. no disrespect intended towards anyone, just believe american made actually means something. deffinately check your connections before anything than take a look at your starter. being your ride has some miles it just may need a lil terminal cleanup.
theres always work in progress
well, i took the starter off and took it to autozone, and it checked out fine, i'm about to go and try to turn the flywheel by hand to see if that works, if not i'm screwed its gonna be a bitch especially if it jumped time and fucked up the valves etc
Alpine cda-105
now go and find your loose conection, oh and how do you know you have plenty of juice in the battery?
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
i've got an everstart maxx, and yellowtop, and its dropping to 10 volts when i crank it. I tried turning the flywheel by hand, turns one way, but stops dead at a certain point in the opposite, i havent tried turning it 360. So looks like it jumped time so tomorrow i'm gonna take off the timing belt cover and see whats up. This sucks when i have finals coming up.
Alpine cda-105
well, i got to the crank and the timing belt was a lil loose and when i rotated the crank it would turn almost a full 360 before stopping abruptly like the piston was hitting a valve, same happened when i rotated it the opposite way. I havnt done a repair like this, and time is very limited with finals coming up so i could definitely use some input :help:
Edited by Chris from Mi
Alpine cda-105
if you suspect the timing is off, pull the crank pulley and cover(s) and check the marks, diagram attached
i wouldnt go that route, it sounds like its in the starter circuit as suggested
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
