Need Some Help With Aero Port Design.
actually, with calculations, a 9.3 cubic feet box, tuned to 33hz would need ~25" of port each if you want to do 4 6" ports.
if you want to do 2 6" ports for the box, you would only need ~12" each
your math is wrong.... note when i run the 3 of the 4 ports it would be 33hz
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
Slightly off topic.
I know for slot ported boxes, it is ~16 sq. in. of port per cu. ft.
Is there a rule like that for aero ports?
You do not have to have that much area for aeros for daily bumping. You have to experiment to get the best combination if you are going for all out SPL.
16 sq in is just a rule of thumb for slot ports. You really have to look at the overall picture. think about it - Does a 15" sub with just a few mm of excursion getting 300 watts in a 4 ft^3 box need as much port area as a 15" with 3" of excursion getting 4000 watts in the same 4 ft^3 box??? I know people will disagree, but the answer is no. The port size really needs to be sized based on the amount of air that will be moving through it to keep the velocity below a certain level.
Brian
Current system:
Previous systems:
Here is a build we're finishing up with two 15's and a single 10" aeroport which is about equal to 3 6" aero's. You will do fine with three or even four 6" aero's but three 6" aeros my possibly sound a little better and have more range. Just keep in mind that the down fall with aeroports is with to much port area the box will be loud as hell but won't play very flat for music. So you're on the right track to running 3 for daily and 4 for spl.
http://www.caraudio.com/forum/showthread.p...ighlight=xterra
oh ok, well then for 38hz, and 4 6" ports, you would need ~19" flared ports. or ~18" straight ports
yea. go for it. i have 2 6" in my box right now. i like the aeros better.
sorry about the confusion.
Ok here is my last question...
Which port arrangements do you guys thing would work the best.
I was gonna go with #1, but then one I plug one. it would make them un even loaded on the subs.
So I am leaning toward #2, what do you guys think.
#1
#2
*1) AudioQue 20k
So if I did number two, which port would i plug? doesn't really matter does it sense they are all gonna be un even no matter which one.
*1) AudioQue 20k
You would have to test to see which it sounds best with plugged. I would try each one of them and then decide which one to keep plugged once I knew what it was going to sound like.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
  • Who's Online   0 Members, 0 Anonymous, 1456 Guests (See full list)
