I need some help. I have done tons of box design. But I never really design boxes that use aero ports.
Im designing a box for 4 12"s that is 9.3 cubes. I was thinking 4 6", which is 113sq inches of port which is what I am guessing is about right. I know you dont have to use as much port area when using flared ports, instead of normal ports.
Is that the proper amount of port area?
Here is my real problem. To tune to my daily freq (33hz) they ports would be over 17" long, which is as long as they make it.
How guess have any suggestions? this would be alot easier then doing a interchangeable slot port. But I cant get the numbers to work.
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
You don't need that much area with aeros. . .(3) 6" would be fine for (4) 12's That is still over 20 sqin of port per 12 and should cut the length down to 17" long.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
that makes my life easy then ill do 4 6", run 3 6" daily tuned to 33hz.... then unplug the 4th and run 4 6" at 38hz...
you guys think its worth the $130 in ports
*1) AudioQue 20k
not really 130$ in ports i got with slot and make it remove able for tuning one for daily and one for comp
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
Absofuckinlutely. It will be the best $130 that you've spent on the box. I think that it's a great idea to run 4 and plug one of them for daily. I have 6 4" aeros right now for my 2 15's, but I have 2 more waiting to be put into a new box. That will be 8 4" aeros and probably 2 or even 3 will be plugged for daily. You won't regret the aeros, that's all I will ever use again in my boxes unless I do a wall.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I want to understand you correctly, you're spendin 130 on 4 6" areos?
Team Soundstream
Team Optima
Team HK
2 Soundstream SPLX-152HX
2 Soundtsream TRX2000D
1 Soundstream RUB4.600
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream S-Cell400
1 Soundstream Power Plant
1 Soundstream BX-15
1 VMAX CT1900
2 Optima Yellow Top D34/78
1 Kenwood KDC-X493
actually, with calculations, a 9.3 cubic feet box, tuned to 33hz would need ~25" of port each if you want to do 4 6" ports.
if you want to do 2 6" ports for the box, you would only need ~12" each
Slightly off topic.
I know for slot ported boxes, it is ~16 sq. in. of port per cu. ft.
Is there a rule like that for aero ports?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 5415 Guests (See full list)
