I wired my subs to 2 ohms today. Just like on the Rockford Site. But my Dmm is reading 1.5 ohms. Is this normal or what. I gotta run 2 Sundown Saz1500d's @ 2 ohms? Will I be able to do it or will I mess the amps up? Go into protect. What will happen. I am running the Fi 15" BL Dual 2 ohm subs.
No sub is truly 2 ohm they are a little off, After box rise its over 2 ohm you will be fine.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
Fi subs never read what they say they are. As Kicker guy said you should be fine running them.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I wired my 2 dual 2 ohm DC audio level 3 subs and I get 1.2 ohms at the amp. Tell me how it does that. lol I think it will be fine too.
On most specs list it will have the actual resistance
BTL 15
DUAL 1 | DUAL 2
Fs: 35.6 Hz | 34.6 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.72 | 5.90
Qes: .24 | .22
Qts: .23 | .22
Mms: 256g | 272g
Sd: 810cm^2 | 810cm^2
Vas: 71.6 l | 71.6 l
Spl: 93.2dB 1W/1m | 93.1dB 1W/1m
Bl: 18.3 N/A | 27.2 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 3-5cuft | 3-5cuft
Sub OD: 15.625” | 15.625”
Cut ID: 14.125” | 14.125”
Mounting depth: 8.750” | 8.750”
Displacement: 0.21cuft | 0.21cuft
Edited by 916PublicEnemy2
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
Uhh that happened to me. I had 2 DVCs 4ohm each. When wired to 2 ohms I got 0.7ohms. Anything below 1.5 is weird for 2ohms...
In my case, one of the VC's measured to 1ohm instead of 4ohms... It also wasn't performing as well.
I basically blew the sub
That really is not the same. I have 4 voice coils at 2ohms each that equal 1.2 at the amp. It should equal .5 or less.
  • Who's Online   0 Members, 0 Anonymous, 1605 Guests (See full list)
