3 Sundown NSv2 15s/ AA500.1 build pg 21 new vids
nice. you're impedance was rising to 5 ohms? jeez dude, i've never had any of mine rise a full ohm over what it was intended to be at.
i also use 8 or 10 gauge speaker wire when i can though.....
the box was really small only 2 cubes... the only reason i kept it in was because the lows were so nice with it. but this box is about 4.1 cubes so i hope it stays close to 1.
i use 8 gauge from amp to box then it split to 10 gauge. i gotta get some more from darvex soon though all 8 gauge this time
I got a little more done
I cut the whole for the sub, put it some t-nuts, and put in the threaded rod. now i just have to find my small bolts to make the terminals. I used some carriage bolt with the theaded rod mainly to keep the bottom of the box close to flat so it lays down better
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
those expensive little things. almost $4 each
Posted Image
Posted Image
i had to screw that nut over 3 feet. then i had to do it again for the other one.
Posted Image
Posted Image
Posted Image
Beautiful build, i've been tuned in for some time and will keep looking.
A+ kerf work
-Drew
uhoh_45 said:
That box is sexellent!!!!!!!!!
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
this was my first time using threaded rod to brace a box.. i think i may have over done it
Can't overdo bracing.
Nice work on those kerf's and the box.
nothing new done yet. these finals are takin up my free time. I did get the sub test fit, and talk about close measurements, the motor has about half a centimeter of room between the two long pieces of threaded rod that go across the width of the box.
