Im just looking for something cheap somewhere in the $20 ball park with shipping. I found a set of PG RSD tweets with the x-over for $20 shipped. Are these tweeters and x-overs decent enough for daily listening?
Or have any of you played with any of these:
Soundstream TWS.4
Planet Audio P18TW
MA Audio MA588
Cadence ZRS75-T
The System In Progress
Headunit: Pioneer DEH5800MP
Sub: DC Sound Lab Level 4 15" D2
Box: 4 cubes at 33Hz
Sub Amp: Cadence Z1200
Front Stage: PG RSD5cs
Rear Stage: Pioneer TSA6991R (Temporary)
Front and Rear Amp: Cadence TXA3004 (FS) (Looking)
Wiring: XScorpion, American Bass, Stinger Custom Pro 4 Gauge
If you don't buy them mind passing the lnik or info onto me...I need another set of xovers and tweets.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Im getting them if I cant find a better deal.
Thats what I figured. Whats the diameter of the tweeter? I cant find specs for it.
For flushmount 2".
My YouTube Videos
Hmm probably flush mount is the way Ill go. Is there screw holes to put in or does it just push in?
Flush mounting the tweeters will usally have some sort of a cup that the tweet rests in, then you just cut a hole in the door panel or where ever your mounting the tweeters (just make sure you have enough clearence behind the panel or where ever your mounting them before cutting a hole).
Theres a lot of different ways for securing the flushmount tweeters in. It seems to vary with company to company. I know Alpine uses a flush mount cub that goes thru the hole and the back side of the cup is threaded and comes with a big nut so to say you screw on agaist the back and this holds them in place really tight. I really think alpine has the best setup for mounting imo.
Diamond audio also uses the same technique as the alpines.
Then some other companies use just little metal brackets that are bent kinda funky and they get screwed into the tweeter cup with a screw, but these prongs never seem to hold completly tight and bend sometimes over time or get a little loose. I guess some of these brackets work better then others, some have 4 tabs while some only have 2 tabs that hold the tweeter tight to the door. I know the Power Acoustik NB.1 and NB.2 use the 2 prong metal tabs to hold them in. Im trying to find pics of the mounting hardware for this style but not much luck. :(
