what is your test cd? Also, are you going to slick the inside of the box, like a boat, somewhere on here someone said that they gained from making the inside of the box really smooth.
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
I just use sine waves on the iPod. DB Drag has an official CD that has the same thing on it.
And yes - resin work is on the to-do list.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
i like this thread! i also read that rounding over the edges of the sub cutouts on the INSIDE of the box could help gain. i think i read that from nightshade...so you may already know that cuz he lives around there right? but either way i think that'd be good to see on the 'to do' list if it's not already there.
damn i wish this thread was done already lol so i know what to do and what not to do to my box. so far the only thing i planned on doing was a 45 in front of the port opening and the terminals. i'll make sure to get some good quality ones tho. possibly resin the inside as well
Woops - I made a mistake earlier... must have looked at the wrong data for the subs I was using before. They are 3.0 DCR and not 3.5 DCR as I was assuming before.
With those D4 coils all in parallel I had 0.375 DCR per amp, which is more like a 0.5 ohm nominal load.
With the D1 Nightshades I built I have an actual 0.50 DCR load per amp, which is more like 0.70 ohms nominal.
Even still... it is doing 154.3 dB with a DCR much higher.
I may have to wire the amps down lower and try it that way with these coils. Or use a different amp configuration like four 1500Ds wired down to 0.25 DCR each to get a better comparison.
- Jacob Fuller
So far the 1500s aren't much liking the 0.25 load. I can roll it and get a score but not high enough to do a GOOD score.
So I may just need to wait for 3500s and use the 0.5 DCR load for now and then build some other subs later once I get it all dialed it for the 0.375 DCR load again.
- Jacob Fuller
Just an fyi for everybody I tried the pvc at the ends of the ports and lost .5 db also tried a 45 at backside of the port and lost an additional .1 which goes to show you every install will have different results.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
