well my story goes like this after about 10 years away from the car audio scene, i found some of Steve's video's and i started doing my home work about the new epuipment out and about ect.
so i finally bought a Rockford t1000-bd and a RE SE 15 (2ohm)dvc. wired to the spec
Then i built a 4 cu.ft. "L ported" enclosure that would fit in my 01 alero's trunk. i have all rockford wires.
It has worked great for about 4 months then last night on my way into work i was jammin for like 5 mins max. trying to get in the mood to be at work and the system went flat(no bass) and all kinds of smoke started rolling out of the box so i shut the system off and pulled over and sure as sh!@ the woofer was hot as hell!
the gain on the amp is set at 1/4. i do use the remote bass knob the amp came with.
can anyone comment on why this could have happened?
what should i do know? please no insults!
upon closer inspection the fuse on the amp seems to have melted a "very little" i will get the amp tested this week and see where it goes from there. is it worth fixing if need be?
Thank you
Dave
Edited by bonez1203
Kenwood KDC-X792 Mb quart 4x6
Mb quart 4x6 front stage
MB quart 3way 6x9
0/1 ga. Rockford wire
The Big 3. 0/1 ga.
Rockford t1000bd broke
RE SE 2ohm DVC 15"
4 cu ft ported enclosure
600 rms sub on prob about 1400rms not really hard to understand what happened
yeah i think you have a point. time for a FI?
MB quart 3way 6x9
The Big 3. 0/1 ga.
RE SE 2ohm DVC 15"
if ur fuses melted that makes it easy:
when u dont have a sufficent electrical to back up ur amp... the voltage drops... thus the amp pulls more amperage
then you used the bass knob, which really u dont need, at all... and likely u were playing music that was distorted, thus ur sub overheated by the dc waves being sent thru it
you also have a large box for that sub... well personally i would have done 4cuft also but since thats at the high end of box volume, it will also take less power to achieve the same output
so in 3cuft you could have given it 750-800w... in 4cuft i wouldnt really go over 700 just because the sub doesnt need more than 650-700ish
you also didnt mention ur tuning or port surface area... if u tuned high, and played low songs like White Girl and Put On, u could have also damaged the sub mechanically
two se's would have been perfect on that amp fyi
food for thought*
Probably or dc audio or ascendant audio or audioque subs.
At decafcappucinno i think it's just because it's too much power, because there was magic smoke.
Edited by kirill007
x2, if your voltage was terrible, theres no point in buying a more expensive speaker and then end up blowing it also from undervolting.
you can get smoke from overpowering a speaker with a CLEAN signal, overpowering with a clipped signal, playing a clean signal with low voltage, which makes the amp clip.
Edited by Krannyman92
he doesnt need another brand the RE brand is perfectly fine he just needs to learn what he needs to put on a sub. DC fi whatever you abuse it and it breaks.
I replied to the mechanical limits part. ;)
you can clip a sub all day long as long as the mechanical/thermal limits arent exceeded...
Try a smaller amp or a bigger sub next time. Set your gains correctly and i dont see this problem happening again anytime soon
Eclipse cd7000
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
