emperorjj1 Posted June 2, 2009 Report Posted June 2, 2009 if its a dual 2 how could you have wired it to 1.4 or 2 ohms in the first place? only used one coil? J. JMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
Derrick824 Posted June 2, 2009 Report Posted June 2, 2009 no sound at all even off the bat seems like one of the coils were reversed. normally the speaker would blow first, but i don't know anything about that amp. ^^ Ding Ding. My money's on one coil wired backwards which will typically send an amp into protect but could very well lead to letting out the magic smoke.
audiofanaticz Posted June 2, 2009 Report Posted June 2, 2009 only used one coil?Ive seen this a lot, but more then that Ive seen people wire up 1 coil to the amp correctly and on the 2nd coil they just connect the post and neg together. Normally when they connect the coil like that the sub and amp will still play somewhat normal at low to mid volumes, and go protect happy at a higher volume, and sooner or latter risking a blown amp.
bennett15 Posted June 2, 2009 Author Report Posted June 2, 2009 guessing thats what i did because i had it in series then wires going to the box i just used the + and neg on just one coil when i should have took the + from one coil and the - from the other? 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
Noob_On_Droid Posted June 2, 2009 Report Posted June 2, 2009 I've ran the 1600 and 2000 at .5 ohm full tilt 12v My money is wiring to a dead short and a bad roll of the dice. What size amp was this? And what model? 06 08 or 10?
bennett15 Posted June 2, 2009 Author Report Posted June 2, 2009 its was the 1600 and 08 model 25th aniversarry 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
Boon Posted June 2, 2009 Report Posted June 2, 2009 Can you draw us a little diagram of how you had it wired? You can't wire a D2 sub to 2 ohms... 10.x volts fo' life!
bennett15 Posted June 2, 2009 Author Report Posted June 2, 2009 this is how i have it wired rite now and at the amp i get a 1.4 ohm load when the amp blew i had - to +, - to + then from just one coil i had a wire coming off + to box and wire of - to box and at the amp it read .7 ohm then the amp smoked up when i tested it out. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
emperorjj1 Posted June 3, 2009 Report Posted June 3, 2009 when wired like in the pic it should be the .7 or 1 ohm load. how u wired it when the amp blew is some nonsense that doesnt even exist hence blowing the amp J. JMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
Derrick824 Posted June 3, 2009 Report Posted June 3, 2009 when the amp blew i had - to +, - to + then from just one coil i had a wire coming off + to box and wire of - to box and at the amp it read .7 ohm then the amp smoked up when i tested it out. You had it wired to a dead short. Where's a face palm smiley when you need one?
