when i set my DMM to 200ohm mode and touch the probes together, i get about .6-.7ohms. is that normal?
yea. depending on how cheap or expensive the multimeter is you get more or less internal resistance from just the meter. ive got one that wont go below 1.5 ohms, even when i parallel speakers to 1/4 ohm.
yes cheaper dmm's have resitance in them... when you read you ohm's you have to add .6 .7 if your dmm reads -.6 -.7 and minus if it reads .6 .7
so it it reads .7 and you test a 2 ohm sub should read like 2.7 you minus the .7 your dmm automaticaly has
Edited by Team Bassick (ALPINE)
That is what the leads on your meter are. What kind and how good of a meter is it?
Here's an eye opener for ya....
http://www.stevemeadedesigns.com/board/ind...mp;#entry658450
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
my fluke reads 0.0 with thr probes shorted
DC.jpgDC POWER
also an aged battery in the dmm will cause readings to be off and or jump around more
x2
omg. How did i forget that.
I ended up running a amp at .2 ohms because of this. DMM varied from .9 to 1.2 or so, meh I just thought it was rise. :(
