would two 6 inch aero ports suffice for enough port area for a single lvl 5 18 in about 7.5 cubes before displacements?
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
with the aero ports it is a good rule of thumb to use something like 8-14 in^2 of port surface area...
Edited by shainemcconnell
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
so yeah 2 or maybe 3, if not much displacement
Team Pure Pressure
Honestly 7.5 cubes is too much for that sub. I'd try putting it in around 6 cubes with the 2 6" aeros and I bet that you'll be much happier with the results. Anything over 6 cubes is honestly too big for an 18 Imo.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
The DC website says recommended space for a SPL setup is 8 cu. ft.
Is the DC website wrong?
Edit: I built a 8 cu. ft. test box for my lvl 5 18 and it seemed good...
Edited by micahmye
The key word there is SPL. I'm willing to bet that he's not putting this 18 in a wall where 8 cubes is a good airspace to have it in for spl. With that much airspace behind the cone there is much more chance that the woofer will be damaged, especially with quite a bit of power on it. That is why I suggested a smaller box, to bring up the impedence rise some and keep the cone under controll.
1 XS Power D3100
Audio Control LC6i
Stock Deck
How much power are you running on this sub? THAT'S what determines how big your port needs to be.
The more power you use, the more air the vent should be designed to accomodate. :hairtrick:
itll be seein around 2600 rms, and that 7-7.5 cubes before all displacements so u figure the standard 18 is around .26-.30 cubes displacement and then port displacement, and then all bracing displacement. so most likely around 6.5-7 cubes max
Edit: and i can always cut the box size after i build also its as simple as a circular saw and some straight lines ya know. I would rather start off to big and be able to cut it down than to small and have to totally rebuild as i dont have that kinda money. :(
Edited by Moore941
1 Dc lvl5 18
shootin for 145+ :)
alright so here are the specs i have so far 43w x 19.5h x 18d and with port and sub and bracing displacement im figuring around 1 cube with all displacement still gotta work out tuning and such but its a rough estimate so far may go just a bit bigger on the box. this is putting the box around 6 cubes with all displacement which is what i originally planned on running, and yes this will be a daily setup anyone know how to calculate round port lengths and tuning looking for around 34-36hz tuning wise
1 Dc lvl5 18
shootin for 145+ :)
Bump for help :hairtrick:
1 Dc lvl5 18
shootin for 145+ :)
